Have seen that there are many issues for some and none for others have they that have issues with they car tried a full reset of the car (multiple times) and seen if that may solve some issues ?
Beiträge von NIGHTCD
Wenn ich automatische Software-Updates in der App aktivieren möchte, erhalte ich die Nachricht, dass nur der Eigentümer dieses aktivieren kann 🤔 Wer ist denn der Eigentümer meines EX30, wenn nicht ich????
Hi, had the same with my car. and my issue was that the previous owner was registered as owner on the car.
Have also seen that the sales representative has registered their email address, this also make the same issue that you encounter.
have a talk with the support team and they should fix the issue for you. (had 4 conversations with the support team and they did not managed it, so had to talk to the guy in the garage that fixed my issue after i got him to see what email address that was registered.
Do we need to purchase the Android app for use in the EX30?
Vel, det er helt nytt..! Så vidt jeg vet, startet OTA alltid minst 2,5 uker etter utgivelse for alle andre oppdateringer - uansett i hvilket land. Det gir håp! (igjen... 🤣)
Yes, ble overrasket selv. Har aldri fått en oppdatering så raskt før i Norge. (Hadde 1.4.2 OTA installert før)
Wie, habe ich das richtig verstanden? OTA wird ausgerollt?
Yes, that is correct
Vises dette også i APP-en når en OTA-oppdatering venter?
Yes
My OTA 1.5 update is installing now, was that not really quick ?
Volvo should be throwing out the latest updates much faster than 3 week after release date, and get focus on what people really needs. (for now it is heat at the least in the cars)
Is the air went for the side windows now working as they should with the 1.5 update?
(Have no air in mine)
Dass der Blinker keinen Sound macht hab ich auch öfter. Einer von den vielen Bugs die ich noch habe. Ich fahre heute mal etwas Autobahn, mal sehen ob er was runterlädt. Ich bezweifle es aber stark
Sounds like you needs a total reset of your car (if you not have tried that), have had some issues like you (and the blinkers sound is not always working due to other equipment using the sound)
